跳转到主内容
Replacing a Patagonia Freewheeler Luggage Handle
你所需要的
视频概述
Freewheeler handle replacement overview.
  1. Replacing a Patagonia Freewheeler Luggage Handle, Handle Replacment: 步骤 1 中的图像 1,2 Replacing a Patagonia Freewheeler Luggage Handle, Handle Replacment: 步骤 1 中的图像 2,2
    • Lay your Wheeled Luggage on its back on a table.
    • Unzip the main zipper.
  2. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 2 中的图像 1,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 2 中的图像 2,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 2 中的图像 3,3
    • Open the main compartment of your bag until it lays flat on the table.
  3. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 3 中的图像 1,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 3 中的图像 2,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 3 中的图像 3,3
    • Unzip the the zipper in the grey lining of the bag, opening the lining as you go.
  4. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 4 中的图像 1,2 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 4 中的图像 2,2
    • Remove the four, red Phillips #1 screws from the frame.
  5. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 5 中的图像 1,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 5 中的图像 2,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 5 中的图像 3,3
    • Remove the two black plastic retaining brackets from the frame.
  6. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 6 中的图像 1,1
    • Depress the button on the handle by gripping firmly.
    • With the button handle still depressed, pull the handle straight out of the bag.
    • This may require some force. If the handle doesn't come out right away you may have to pull harder.
    • When inserting a new handle, be sure to push the handle in until there is a loud click, and the brackets on the handle lay flush with the bag.
  7. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 9 中的图像 1,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 9 中的图像 2,3 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 9 中的图像 3,3
    • If you are still having trouble with your handle, check the pins inside the bag.
    • When you depress the button on the handle, the two pins on the sides of the handle should retract, freeing the handle to slide.
    • If either pin is not retracting use a pencil, screwdriver, or other thin object to push the pin into the hole.
  8. Replacing a Patagonia Freewheeler Luggage Handle: 步骤 10 中的图像 1,2 Replacing a Patagonia Freewheeler Luggage Handle: 步骤 10 中的图像 2,2
    • With the pin depressed, squeeze the handle and pull it from the bag.
    Buongiorno, dovrei sostituire il manico della mia valigia, ma aprendo la tasca interna, per rimuovere il vecchio manico, è tutto cucito. Come faccio a rimuovere quello vecchio e installare quello nuovo?
    bgirlgiop - 回复
结论
5等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,017 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
2条评论
I depressed the pins. It worked once or twice. But now, I have to depress the pins every time to get the handle to work OR even with the pins depressed it will still not retract or if retracted it will still not open.
What is the solution?
I love this suitcase otherwise, but the handle has always been tricky needing just the right angle on the way in and having to jiggle it to get it out.
Help Patagonia!
Sharon - 回复
Hi Sharon,
The solution to depress the pins was meant to be a temporary solution when your handle is stuck in the extended position. Unfortunately, it means that your handle needs to be replaced as the handle trigger mechanism and pins are not functioning properly. Contact Patagonia for a new handle. You can either call us and we will can ship you a new one and you can replace yourself, or you can go to a Patagonia Retail Store and get a new handle there, afterwhich you can use the handing guidelines for replacement. Please visit our website for phone number and to locate a store near you. Copy and paste this URL in your search engine bar or click on the link.
http://www.patagonia.com/us/patagonia.go...
Marty Chapman -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 89
过去 30 天: 296
总计 29,967
