跳转到主内容
Replacing a Broken/Cracked Window Blind Slat
你所需要的
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: 步骤 1 中的图像 1,2 Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: 步骤 1 中的图像 2,2
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: 步骤 2 中的图像 1,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 2 中的图像 2,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 2 中的图像 3,3
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: 步骤 3 中的图像 1,1
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: 步骤 4 中的图像 1,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 4 中的图像 2,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 4 中的图像 3,3
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: 步骤 5 中的图像 1,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 5 中的图像 2,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 5 中的图像 3,3
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: 步骤 6 中的图像 1,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 6 中的图像 2,3 Replacing a Broken/Cracked Window Blind Slat: 步骤 6 中的图像 3,3
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: 步骤 7 中的图像 1,2 Replacing a Broken/Cracked Window Blind Slat: 步骤 7 中的图像 2,2
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
结论
Moses Matovu
于03/22/21注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 109
总计 5,009
