简介
You will learn how to change a worn out grip on a baseball bat. When the grip begins to tear or shred is usually when an old bat is thrown away; this repair will help you keep a bat longer with no skills required to replace the grip. You will need a clean flat surface to work on as you are guided through removing the old grip, cleaning the handle, and putting a new grip on.
你所需要的
Place the bat on a firm surface with the grip hanging off the edge.
Draw a line on the top of the old grip using a marker.
Use the utility knife to cut the tape where you made your mark.
Peel off the old grip.
9等其他人完成本指南。
