跳转到主内容
Replacing VuPoint DC-ST210-VP View Finder
你所需要的
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: 步骤 1 中的图像 1,1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 步骤 2 中的图像 1,3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 步骤 2 中的图像 2,3 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: 步骤 2 中的图像 3,3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: 步骤 3 中的图像 1,2 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: 步骤 3 中的图像 2,2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: 步骤 4 中的图像 1,1
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
结论
Dorey Chiu
于10/26/14注册
1 声望
撰写一个指南
团队
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G15
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 328
