跳转到主内容
Replacing VTech MobiGo Touch Learning System Speaker
你所需要的
  1. Replacing VTech MobiGo Touch Learning System Speaker, Case: 步骤 1 中的图像 1,1
    • Remove the battery covers and the four batteries.
  2. Replacing VTech MobiGo Touch Learning System Speaker: 步骤 2 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker: 步骤 2 中的图像 2,2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Replacing VTech MobiGo Touch Learning System Speaker: 步骤 3 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 步骤 4 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: 步骤 4 中的图像 2,2
    • The speaker will be attached to the back of the case.
    • Unscrew the two 6.0 mm Philips J0 screws.
    • Careful! The wires are still attached to the back of the case and to the speakers.
  5. Replacing VTech MobiGo Touch Learning System Speaker: 步骤 5 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker: 步骤 5 中的图像 2,2
    • Lift the round speaker with a plastic opening tool.
    • Remove the two wires connected to the speaker.
    • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
    • Once the wires are disconnected, remove the speaker from the back of the case.
  6. Replacing VTech MobiGo Touch Learning System Speaker: 步骤 6 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker: 步骤 6 中的图像 2,2
    • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
    • The wires may be hot.
  7. Replacing VTech MobiGo Touch Learning System Speaker: 步骤 7 中的图像 1,2 Replacing VTech MobiGo Touch Learning System Speaker: 步骤 7 中的图像 2,2
    • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
    • Make sure the speaker is the right size for the panel.
    • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
    • Do not over tighten the screws or the panel will break.
结论
To reassemble your case, follow the case instructions in reverse order.
RBansil
于08/27/15注册
221 声望
创作了2篇指南
团队
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G3
3 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 214
总计 1,890
