跳转到主内容
Replacing Tungsten E screen. PAL5037
你所需要的
  1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: 步骤 1 中的图像 1,2 Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: 步骤 1 中的图像 2,2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Replacing Tungsten E screen. PAL5037: 步骤 2 中的图像 1,3 Replacing Tungsten E screen. PAL5037: 步骤 2 中的图像 2,3 Replacing Tungsten E screen. PAL5037: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Replacing Tungsten E screen. PAL5037: 步骤 3 中的图像 1,2 Replacing Tungsten E screen. PAL5037: 步骤 3 中的图像 2,2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Replacing Tungsten E screen. PAL5037: 步骤 4 中的图像 1,2 Replacing Tungsten E screen. PAL5037: 步骤 4 中的图像 2,2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Replacing Tungsten E screen. PAL5037: 步骤 5 中的图像 1,3 Replacing Tungsten E screen. PAL5037: 步骤 5 中的图像 2,3 Replacing Tungsten E screen. PAL5037: 步骤 5 中的图像 3,3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Replacing Tungsten E screen. PAL5037: 步骤 6 中的图像 1,1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Replacing Tungsten E screen. PAL5037, Replacing Touch screen: 步骤 7 中的图像 1,1
    • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
    • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
    • Be careful not to damage the flex connector.
结论
3等其他人完成本指南。
Kevin Hom
于01/21/10注册
103 声望
创作了2篇指南
团队
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G22
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,466
