跳转到主内容
Replacing Strings on a Mandolin
你所需要的
  1. Replacing Strings on a Mandolin, Mandolin Strings: 步骤 1 中的图像 1,1
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: 步骤 2 中的图像 1,1
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: 步骤 3 中的图像 1,1
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: 步骤 4 中的图像 1,1
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: 步骤 5 中的图像 1,1
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: 步骤 6 中的图像 1,1
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: 步骤 7 中的图像 1,1
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: 步骤 8 中的图像 1,2 Replacing Strings on a Mandolin: 步骤 8 中的图像 2,2
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: 步骤 9 中的图像 1,1
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: 步骤 10 中的图像 1,1
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: 步骤 11 中的图像 1,1
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: 步骤 12 中的图像 1,1
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: 步骤 13 中的图像 1,1
    • Commence rocking on with your Gretsch New Yorker!
终点
3等其他人完成本指南。
Drew
于03/18/15注册
125 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 26
总计 7,750
