跳转到主内容
Replacing Strings on Floating Tremolo Bridge Guitar
你所需要的
  1. Replacing Strings on Floating Tremolo Bridge Guitar, Strings: 步骤 1 中的图像 1,3 Replacing Strings on Floating Tremolo Bridge Guitar, Strings: 步骤 1 中的图像 2,3 Replacing Strings on Floating Tremolo Bridge Guitar, Strings: 步骤 1 中的图像 3,3
    • Use a string winder to loosen each string by turning the peg counter-clockwise.
    • Once loosened, pull the string out of the tuning peg.
  2. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 2 中的图像 1,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 2 中的图像 2,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 2 中的图像 3,3
    • Move to the bridge of the guitar and push the strings through.
    • Flip the guitar around and pull the string out of the hole in the back.
  3. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 3 中的图像 1,2 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 3 中的图像 2,2
    • Insert the new strings through the holes in the back.
    • Many strings will be color coded or have guides so you'll know which holes to put each string through.
    • Feed the string through to the other end and pull until the end of the string is reached.
    • You will know if you reached the end of the string if you can't pull any further.
  4. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 4 中的图像 1,1
    • Turn each tuning peg until the holes are perpendicular to the nut.
    • The nut is the piece of wood with grooves that hold the strings.
  5. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 5 中的图像 1,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 5 中的图像 2,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 5 中的图像 3,3
    • Align each string to the groove in the nut.
    • Insert the strings into the corresponding tuning peg.
    • Leave about an inch or 2 of slack.
  6. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 6 中的图像 1,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 6 中的图像 2,3 Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 6 中的图像 3,3
    • To tie the knot, begin by looping the string around and then under.
    • Pull up on the string until you can feel tension.
    • Loop the string over and pull.
  7. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 7 中的图像 1,1
    • Tighten the string using the string winder.
    • One or two rotations should do the trick.
    • Be careful not to tighten the stings too much, the strings may snap under excessive tension.
  8. Replacing Strings on Floating Tremolo Bridge Guitar: 步骤 8 中的图像 1,1
    • Snip off the excess string at the end.
    • Keep a safe distance when cutting each string. It can snap and hit your face or skin. Be extra careful to protect your eyes.
结论
All that's left to do is tune your guitar and then it will be ready for playing!
PATRICK B COLORINA
于09/10/23注册
157 声望
撰写一个指南
团队
York University, Team 1-9, O'Regan Fall 2023 York University, Team 1-9, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G9
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 234
