跳转到主内容
Replacing Sonos Play 1 Power and Volume switch board.
你所需要的
  1. Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: 步骤 1 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: 步骤 1 中的图像 2,2
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 2 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 2 中的图像 2,2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 3 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 3 中的图像 2,2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 4 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 4 中的图像 2,2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 5 中的图像 1,1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Replacing Sonos Play 1 Power and Volume switch board., Sonos Play 1 Top Cover Disassembly: 步骤 6 中的图像 1,1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 7 中的图像 1,3 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 7 中的图像 2,3 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 7 中的图像 3,3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 8 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Replacing Sonos Play 1 Power and Volume switch board., Power and Volume Switch Board: 步骤 9 中的图像 1,1
    • Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
    • Using you fingers remove the protective plastic plate covering the device.
  10. Replacing Sonos Play 1 Power and Volume switch board.: 步骤 10 中的图像 1,2 Replacing Sonos Play 1 Power and Volume switch board.: 步骤 10 中的图像 2,2
    • Using your fingers remove the plastic cover plate securing the switchboard.
    • Using your fingers, remove the power/volume switch board.
结论
4等其他人完成本指南。
Patty
于09/01/15注册
450 声望
撰写一个指南
团队
USF Tampa, Team 8-4, Eyestone Fall 2015 USF Tampa, Team 8-4, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G4
4 名成员
创作了16篇指南
9条评论
Where can I get the replacement power button?
Teresa Rosales - 回复
I would like to know as well
hung pham - 回复
Dear Patty
Where can I buy the switchboard?
Thanks in advance. :-)
/Kenneth
Kenneth - 回复
Same quesion here from DK
Lars Jürgensen - 回复
where can i find board
craigmdyer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 63
总计 8,675
