简介
The circuit board is the component of the phone that allows communication between all of the inputs and outputs within the phone in order to perform tasks that the user requires.
  1. Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Make sure the phone is turned off by pressing the power off button to ensure no data is lost.
    • Remove the back battery cover by sliding it downward and pushing simultaneously.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • Using either your thumb or the opening tools, remove the battery by prying the battery out in the direction of the arrow.
    • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
  3. Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by inserting the tip of the metal tweezers down around the plastic insert. Remove the rubber inserts from the screw holes using the black metal tweezers.  This is done by inserting the tip of the metal tweezers down around the plastic insert.
    • Remove the rubber inserts from the screw holes using the black metal tweezers. This is done by inserting the tip of the metal tweezers down around the plastic insert.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the 3.1mm long, Phillips #00 screws (Qty: 4)  from the corners. This is done by turning the screwdriver counter clockwise using little torque. This is done by turning the screwdriver counter clockwise using little torque.
    • Remove the 3.1mm long, Phillips #00 screws (Qty: 4) from the corners.
    • This is done by turning the screwdriver counter clockwise using little torque.
  6. Separate the phone's front case from the back case. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well. There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
    • Separate the phone's front case from the back case.
    • There is an intermediate decorative outlay around the front cases perimeter. This should be removed as well.
  7. Remove volume slider button by using the tweezers to pry it out.
    • Remove volume slider button by using the tweezers to pry it out.
    • The volume slider button may fall out during the seperation of the front and back cases, this is ok.
  8. Using the opening tools, separate the circuit board from the inside of the back case by prying between the circuit board and the case as shown. The last picture is a view of the back of the circuit board. The last picture is a view of the back of the circuit board.
    • Using the opening tools, separate the circuit board from the inside of the back case by prying between the circuit board and the case as shown.
    • The last picture is a view of the back of the circuit board.
结论
John Bender
于2014年03月26日注册
822 信誉积分
创作了8篇指南
团队
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G5
3 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 139
