简介
This is an easy guide to replacing the rear buttons on the Sanyo VPC-X1200.
  1. Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Gently lift up the back cover and set aside.
    • Gently lift up the back cover and set aside.
  4. Use small plastic pry tool to gently remove rear button plate.
    • Use small plastic pry tool to gently remove rear button plate.
    • A heat gun may be used to soften the glue for easier removal.
结论
Anthony Giardina
于2010年04月19日注册
20 信誉积分
创作了7篇指南
团队
Cal Poly, Team 7-10, Maness Spring 2010 Cal Poly, Team 7-10, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G10
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 1,330
