简介
It is fairly simple to replace the bread lift shelf, even though the metal flaps holding the bread lift shelf can be difficult to access.
你所需要的
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Use a flat-head screwdriver to separate the metal flap from the metal plate.
即将完成!
结论
