简介
It is fairly simple to replace the bread lift shelf, even though the metal flaps holding the bread lift shelf can be difficult to access.
  1. Using the Phillips-head #2 screwdriver,  unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base. Using the Phillips-head #2 screwdriver,  unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base. Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Lift the top outer metal shell. Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  7. Use a flat-head screwdriver to separate the metal flap from the metal plate.
    • Use a flat-head screwdriver to separate the metal flap from the metal plate.
  8. Grasp the metal flap with the large needle nose pliers. Unbend metal flap until at a 90 degree angle from the metal plate.
    • Grasp the metal flap with the large needle nose pliers.
    • Unbend metal flap until at a 90 degree angle from the metal plate.
    • Repeat these steps for the second metal flap.
  9. Use the large need nose pliers to grab the  metal panel.
    • Use the large need nose pliers to grab the metal panel.
    • Pull the metal panel away from the body of the toaster to dislodge the flaps.
  10. Push the metal flaps towards the body of the toaster to access the bread lift shelf. Push the metal flaps towards the body of the toaster to access the bread lift shelf.
    • Push the metal flaps towards the body of the toaster to access the bread lift shelf.
  11. Push down on the opposite side of the bread lift shelf to expose the metal flaps.
    • Push down on the opposite side of the bread lift shelf to expose the metal flaps.
  12. Pull up on the bread lift shelf to remove from the toaster.
    • Pull up on the bread lift shelf to remove from the toaster.
结论
Jason Yoon
于2014年01月31日注册
101 信誉积分
撰写一个指南
团队
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G15
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 385
