跳转到主内容
Replacing Nokia X3-02 LCD
你所需要的
  1. Replacing Nokia X3-02 LCD, LCD: 步骤 1 中的图像 1,3 Replacing Nokia X3-02 LCD, LCD: 步骤 1 中的图像 2,3 Replacing Nokia X3-02 LCD, LCD: 步骤 1 中的图像 3,3
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Replacing Nokia X3-02 LCD: 步骤 2 中的图像 1,2 Replacing Nokia X3-02 LCD: 步骤 2 中的图像 2,2
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. Replacing Nokia X3-02 LCD: 步骤 3 中的图像 1,3 Replacing Nokia X3-02 LCD: 步骤 3 中的图像 2,3 Replacing Nokia X3-02 LCD: 步骤 3 中的图像 3,3
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  4. Replacing Nokia X3-02 LCD: 步骤 4 中的图像 1,2 Replacing Nokia X3-02 LCD: 步骤 4 中的图像 2,2
    • Remove the keyboard with a plastic opening tool.
结论
13等其他人完成本指南。
Matteo Moro
于02/21/13注册
536 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 4,789
