跳转到主内容
Replacing Motorola V60i Logic Board
你所需要的
  1. Replacing Motorola V60i Logic Board, Battery: 步骤 1 中的图像 1,2 Replacing Motorola V60i Logic Board, Battery: 步骤 1 中的图像 2,2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: 步骤 2 中的图像 1,2 Replacing Motorola V60i Logic Board: 步骤 2 中的图像 2,2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: 步骤 3 中的图像 1,1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: 步骤 4 中的图像 1,2 Replacing Motorola V60i Logic Board: 步骤 4 中的图像 2,2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: 步骤 5 中的图像 1,1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: 步骤 6 中的图像 1,1
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: 步骤 7 中的图像 1,2 Replacing Motorola V60i Logic Board: 步骤 7 中的图像 2,2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
结论
团队
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G40
4 名成员
创作了14篇指南
一条评论
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,187
