跳转到主内容
Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack
你所需要的
  1. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: 步骤 1 中的图像 1,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: 步骤 1 中的图像 2,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: 步骤 1 中的图像 3,3
    • To remove the cover and the headphone jack, follow the instructions of this guide.
  2. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: 步骤 2 中的图像 1,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: 步骤 2 中的图像 2,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: 步骤 2 中的图像 3,3
    • Disconnect the battery ribbon cable.
    • Using a flat object, squeeze the battery bracket on the side of the headphone jack out of the bracket. It should be a robust flat object as some force is needed to get the battery out. Using too much force can damage the case.
    • Carefully pull out the battery ribbon cable together with the battery.
  3. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: 步骤 3 中的图像 1,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: 步骤 3 中的图像 2,3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: 步骤 3 中的图像 3,3
    • Remove the screw cover on the ribbon cable side (the cover is stuck).
    • Remove the screw and cover. The cover is wedged in on one side and therefore you need some patience to get the cover out.
    • The old battery can then be replaced. Pay attention to the type designation of the old and new battery when replacing it.
结论
Repeat the steps in order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Raphael Hinterndorfer
于02/11/19注册
124 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 68
总计 3,499
