跳转到主内容
IBM ThinkPad 560z Screen Replacement
你所需要的
  1. IBM ThinkPad 560z Screen Replacement, Battery Removal: 步骤 1 中的图像 1,1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: 步骤 2 中的图像 1,2 IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: 步骤 2 中的图像 2,2
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  3. IBM ThinkPad 560z Screen Replacement, Screen Bezel Removal: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  4. IBM ThinkPad 560z Screen Replacement, LCD Removal Preperation: 步骤 4 中的图像 1,1
    • Remove the four Phillips head screws.
  5. IBM ThinkPad 560z Screen Replacement, Ribbon Cable Disconnection: 步骤 5 中的图像 1,1
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  6. IBM ThinkPad 560z Screen Replacement, LCD Removal: 步骤 6 中的图像 1,2 IBM ThinkPad 560z Screen Replacement, LCD Removal: 步骤 6 中的图像 2,2
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
结论
2等其他人完成本指南。
John Allande
于04/15/10注册
64 声望
撰写一个指南
团队
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G27
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 4,954
