简介
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Remove the four Phillips head screws.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
      • The connector is very fragile, so be careful.
结论
2等其他人完成本指南。
John Allande
于2010年04月15日注册
64 信誉积分
撰写一个指南
团队
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G27
3 名成员
创作了18篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 4,541
