跳转到主内容
Replacing Crosley CR42 Needle
你所需要的
  1. Replacing Crosley CR42 Needle, Needle: 步骤 1 中的图像 1,2 Replacing Crosley CR42 Needle, Needle: 步骤 1 中的图像 2,2
    • The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
  2. Replacing Crosley CR42 Needle: 步骤 2 中的图像 1,2 Replacing Crosley CR42 Needle: 步骤 2 中的图像 2,2
    • While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
    • The needle should hang, as shown.
  3. Replacing Crosley CR42 Needle: 步骤 3 中的图像 1,2 Replacing Crosley CR42 Needle: 步骤 3 中的图像 2,2
    • Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
    • WHEN ATTACHING NEW NEEDLE: Slide the back (open U shaped side) of the needle on first, then press to snap the front into place. You should hear a click.
结论
2等其他人完成本指南。
Roberto Rosila
于01/26/14注册
319 声望
创作了3篇指南
团队
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G38
4 名成员
创作了5篇指南
一条评论
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
thmccullough - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 5,137
