跳转到主内容
Replacing Creative Zen X-Fi Motherboard
你所需要的
  1. Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 1,3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 2,3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 步骤 1 中的图像 3,3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Motherboard, Rubber Button Cover: 步骤 2 中的图像 1,1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Motherboard, Button Input Chip Part 1: 步骤 3 中的图像 1,1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Motherboard, Button Input Chip: 步骤 4 中的图像 1,1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Motherboard, Access Midsection Plate: 步骤 5 中的图像 1,1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Motherboard, Unscrew below Button Chip: 步骤 6 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Motherboard, Unscrew below LCD Screen: 步骤 7 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 步骤 8 中的图像 1,2 Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 步骤 8 中的图像 2,2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
结论
另外一个人完成了本指南。
Westley Courchene
于01/13/15注册
3,389 声望
创作了14篇指南
团队
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G1
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 535
