跳转到主内容
Replacing Creative Zen X-Fi Midsection Plate
你所需要的
  1. Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: 步骤 1 中的图像 1,3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: 步骤 1 中的图像 2,3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: 步骤 1 中的图像 3,3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Midsection Plate, Rubber Button Cover: 步骤 2 中的图像 1,1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip Part 1: 步骤 3 中的图像 1,1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip: 步骤 4 中的图像 1,1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Midsection Plate, Access Midsection Plate: 步骤 5 中的图像 1,1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below Button Chip: 步骤 6 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below LCD Screen: 步骤 7 中的图像 1,1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
结论
Westley Courchene
于01/13/15注册
3,410 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 247
