跳转到主内容
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
你所需要的
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: 步骤 1 中的图像 1,1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 2 中的图像 1,3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 2 中的图像 2,3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 2 中的图像 3,3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 3 中的图像 1,2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 3 中的图像 2,2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 4 中的图像 1,2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 4 中的图像 2,2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 5 中的图像 1,2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 5 中的图像 2,2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 6 中的图像 1,2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 步骤 6 中的图像 2,2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 51
总计 3,822
