当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
Do not attempt to remove the screw because it will not come out.
Once the screw is loose, slowly pull out the antenna until it is completely out.
Once the antenna is out, you can replace it with the new one.
Do not force the antenna inside and make sure it is coiled all the way down.
取消:我没有完成这个指南。
2等其他人完成本指南。
Realistic-Weatheradio.pdf
PDF - 27.32 kb
与5其他贡献者
于07/17/15注册
136 声望
撰写一个指南
徽章: 6
+ 3更多徽章
TTU-RAUCH-SU15S3G5
3 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 24
总计 896
