跳转到主内容
Replacing Antenna on Realistic Weatheradio
你所需要的
  1. Replacing Antenna on Realistic Weatheradio, Antenna: 步骤 1 中的图像 1,1
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: 步骤 2 中的图像 1,1
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: 步骤 3 中的图像 1,2 Replacing Antenna on Realistic Weatheradio: 步骤 3 中的图像 2,2
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
结论
After following these steps, the Realistic Weatheradio should be able to work and function normally.
2等其他人完成本指南。
附加文件
Matthew
于07/17/15注册
136 声望
撰写一个指南
团队
Texas Tech, Team 3-5, Rauch SU 2015 Texas Tech, Team 3-5, Rauch SU 2015 的会员
TTU-RAUCH-SU15S3G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 929
