简介
This is a walk through of how to replace the spark plugs in a Dodge Neon. This demonstration is on a 1998 model.
  1. The air vent is covering 4 spark plugs.
    • The air vent is covering 4 spark plugs.
    • Twist off the wing nut on the left (see hand in photo).
    • The big plastic art with the "SO??" marked on it just lifts up and out
    • It sounds like you are breaking something but you are just disconnecting it from the air filter housing.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Image of engine with out plastic cover that was removed in step 1. See the air filter exposed in the back?
    • Image of engine with out plastic cover that was removed in step 1. See the air filter exposed in the back?
    • There are numbers on the top of the engine with wires going to the four spark plugs in the front of the engine (between the oil dipstick and the oil repository).
    • Start with s
结论
4等其他人完成本指南。
Benjamin
于2013年07月16日注册
195 信誉积分
撰写一个指南
How long of an extention rachet do you need to get to the plugs..? Thanks though seems simple enough. Also has anyone changed their plugs in a 98 neon using Bosch Platinum IR infusion plugs... with 4 ground electrodes... I just bought them.. figured they'd work the best... hope not to hot.
Shawn - 回复
I look up different things for my 98' Plymouth neon and always see 2000, or 02' I'm guessing they haven't changed much. Happy to see it with the correct year. Thanks agsin.
Shawn - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 10
总计 3,471
