跳转到主内容
Replacement Ram
你所需要的
  1. Replacement Ram, Ram: 步骤 1 中的图像 1,1
    • Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
  2. Replacement Ram: 步骤 2 中的图像 1,1
    • After removing the screw, using your finger slowly lift out and remove the cover.
  3. Replacement Ram: 步骤 3 中的图像 1,3 Replacement Ram: 步骤 3 中的图像 2,3 Replacement Ram: 步骤 3 中的图像 3,3
    • Lift the flap
    • Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
    • The ram is to be removed at a 45 degree angle.
  4. Replacement Ram: 步骤 4 中的图像 1,1
    • Pull out cleanly and you have now successfully removed the ram.
结论
Eric Martinez
于02/14/17注册
637 声望
创作了6篇指南
团队
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 340
