跳转到主内容
Replace the Slider on a Plastic Tooth Zipper
你所需要的
视频概述
  1. Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 步骤 1 中的图像 1,3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 步骤 1 中的图像 2,3 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: 步骤 1 中的图像 3,3
    • Locate the top of the zipper on the side with the slider.
    • Use end nippers to cut the stop off of the zipper.
    • Be careful to only cut the plastic, not the fabric.
  2. Replace the Slider on a Plastic Tooth Zipper: 步骤 2 中的图像 1,1
    • Use tweezers to remove any remaining pieces of the stop from the garment.
  3. Replace the Slider on a Plastic Tooth Zipper: 步骤 3 中的图像 1,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 3 中的图像 2,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 3 中的图像 3,3
    • Slide the slider off of the garment.
  4. Replace the Slider on a Plastic Tooth Zipper: 步骤 4 中的图像 1,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 4 中的图像 2,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 4 中的图像 3,3
    • Insert the new slider onto the zipper.
    • You may need to tug a little to get the slider over the webbing from the old stop.
    • Make sure the zipper slider is oriented right-side up when you slide it back onto the zipper.
  5. Replace the Slider on a Plastic Tooth Zipper: 步骤 5 中的图像 1,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 5 中的图像 2,3 Replace the Slider on a Plastic Tooth Zipper: 步骤 5 中的图像 3,3
    • Grab a replacement stop.
    • Position the new stop over the webbing in the same place where the old stop was located.
  6. Replace the Slider on a Plastic Tooth Zipper: 步骤 6 中的图像 1,2 Replace the Slider on a Plastic Tooth Zipper: 步骤 6 中的图像 2,2
    • Use pliers to crimp the stop into place.
结论
For replacement parts or further assistance, contact Patagonia Customer Service.
59等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,014 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
23条评论
Where do I get the parts needed?
jonaskrat - 回复
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - 回复
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - 回复
添加评论
浏览统计数据:
过去 24 小时: 196
过去 7 天: 1,330
过去 30 天: 5,200
总计 717,331
