跳转到主内容
Replace the Light Socket in a Desk Lamp
你所需要的
  1. Replace the Light Socket in a Desk Lamp, Light socket: 步骤 1 中的图像 1,3 Replace the Light Socket in a Desk Lamp, Light socket: 步骤 1 中的图像 2,3 Replace the Light Socket in a Desk Lamp, Light socket: 步骤 1 中的图像 3,3
    • Unplug the lamp before starting to avoid electrical shock.
    • Carefully unscrew the bulb by turning it counterclockwise.
    • If it’s tight, use a cloth for better grip and protection.
    • Set the bulb aside in a safe spot.
  2. Replace the Light Socket in a Desk Lamp: 步骤 2 中的图像 1,3 Replace the Light Socket in a Desk Lamp: 步骤 2 中的图像 2,3 Replace the Light Socket in a Desk Lamp: 步骤 2 中的图像 3,3
    • Grip the harp saddle firmly and lift it straight up to release it from the socket base.
    • Some lamps have clips or tension that hold the saddle in place—if yours does, gently squeeze the sides to loosen it.
    • Set the saddle aside for reassembly later.
  3. Replace the Light Socket in a Desk Lamp: 步骤 3 中的图像 1,2 Replace the Light Socket in a Desk Lamp: 步骤 3 中的图像 2,2
    • Turn the light switch handle counterclockwise to remove it.
    • Some handles may be snug, so take your time and avoid forcing it.
  4. Replace the Light Socket in a Desk Lamp: 步骤 4 中的图像 1,3 Replace the Light Socket in a Desk Lamp: 步骤 4 中的图像 2,3 Replace the Light Socket in a Desk Lamp: 步骤 4 中的图像 3,3
    • Gently pull the socket shell up from the lamp base.
    • Some sockets may be snug or clipped in. If so, gently wiggle the socket while pulling to loosen it.
    • Be careful not to pull too hard on the wires—they are still connected underneath.
  5. Replace the Light Socket in a Desk Lamp: 步骤 5 中的图像 1,3 Replace the Light Socket in a Desk Lamp: 步骤 5 中的图像 2,3 Replace the Light Socket in a Desk Lamp: 步骤 5 中的图像 3,3
    • Carefully open the inner socket housing to access the wire connections.
    • Depending on your lamp model, you may need to unscrew the socket, release a locking tab, or separate a snap-fit joint.
    • Use a screwdriver to loosen the terminal screws or clips and gently disconnect the wires.
  6. Replace the Light Socket in a Desk Lamp: 步骤 6 中的图像 1,2 Replace the Light Socket in a Desk Lamp: 步骤 6 中的图像 2,2
    • Release the wire by loosening screws, releasing clips, or pulling them from push-in connectors, depending on the socket.
    • Take note of how the wires were connected for reassembly later.
  7. Replace the Light Socket in a Desk Lamp: 步骤 7 中的图像 1,3 Replace the Light Socket in a Desk Lamp: 步骤 7 中的图像 2,3 Replace the Light Socket in a Desk Lamp: 步骤 7 中的图像 3,3
    • Align the new socket with the metal brackets or prongs on the lamp base, then secure it.
    • Depending on the lamp, snap it into place, twist to lock, or fasten it with screws.
    • Make sure the socket sits firmly and evenly to prevent wobbling.
  8. Replace the Light Socket in a Desk Lamp: 步骤 8 中的图像 1,3 Replace the Light Socket in a Desk Lamp: 步骤 8 中的图像 2,3 Replace the Light Socket in a Desk Lamp: 步骤 8 中的图像 3,3
    • Press the socket cap down onto the base until it clicks or locks into place.
    • If it has screws, replace and tighten them to secure the socket.
    • Reattach the harp.
    • Finally, screw in a working bulb and test the lamp to confirm the repair was successful.
结论
Phieu Pham
于08/27/25注册
157 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 6
总计 21
