简介
First remove the old battery and read the type and then order the new battery. The repair manual is also suitable for the Windows version Lenovo Yoga 2 851F.
你所需要的
To remove the cover and the headphone jack, follow the instructions of this guide.
Disconnect the battery ribbon cable.
Using a flat object, squeeze the battery bracket on the side of the headphone jack out of the bracket. It should be a robust flat object as some force is needed to get the battery out. Using too much force can damage the case.
Carefully pull out the battery ribbon cable together with the battery.
Remove the screw cover on the ribbon cable side (the cover is stuck).
Remove the screw and cover. The cover is wedged in on one side and therefore you need some patience to get the cover out.
The old battery can then be replaced. Pay attention to the type designation of the old and new battery when replacing it.
Repeat the steps in order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
