当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Loosen the 2 thumbscrews on the back of the xserve to release the top.
Slide top back, and lift top off.
This step is not necessary if you are not changing the drive. It does not interfere with the rest of the procedure.
If the hard drives or blanks are still in the xserve, push the handle in to pop it out.
Pull the hard drive and blank sleds out.
Slide lever lock to release the CD/DVD drive.
Slide CD/DVD drive back.
Lift drive up and unplug the SATA connector on the back.
Using a #1 Phillips screwdriver, unscrew the screws on each side of PCI slot #2 on the back of the computer.
Once the screws are loosened, the PCI riser card should lift out of the slot.
Repeat for PCI slot #1
Using a 3.0mm Hex wrench (Allen wrench), loosen the 4 screws that hold the processor and heatsink down.
Unplug the sensor cable.
Lift the heatsink and processor off the motherboard.
Repeat if you have the dual processor model.
Using a #1 phillips screwdriver, loosen the 5 screws that hold the plastic bezel in place.
Remove the plastic bezel.
Using a #2 phillips screwdriver, loosen the 2 screws that hold the fan array in place
Lift the fan array out.
Using the spudger, lift the connector on the right.
Carefully squeeze the connector on the left and unplug it.
Using the spudger, lift the CD/DVD connector by the CPU A RAM slots.
Using a #2 screwdriver, loosen the 9 screws that hold the motherboard in place.
There are 3 rows of 3 screws each. 1 row by the back of the computer, 1 row in the middle and 1 row by the fan array. They are obvious by the black plastic spacer/retainer on them.
Using a #2 screwdriver, loosen the screw on the power board.
Slide it up to disconnect it from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
