跳转到主内容
How to remove scratches from an Airpods Case
你所需要的
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 步骤 1 中的图像 1,2 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 步骤 1 中的图像 2,2
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: 步骤 2 中的图像 1,1
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: 步骤 3 中的图像 1,1
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: 步骤 4 中的图像 1,2 How to remove scratches from an Airpods Case: 步骤 4 中的图像 2,2
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: 步骤 5 中的图像 1,1
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: 步骤 6 中的图像 1,1
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: 步骤 7 中的图像 1,1
    • Refreshed now!
结论
This will give the charging case a refreshed look instead of a dirty, scratched surface.
27等其他人完成本指南。
由衷感谢以下译者:
zh en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Z.Heng
于04/08/17注册
3,610 声望
创作了3篇指南
8条评论
Extremely convincing, especially the last picture.
Ludger - 回复
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - 回复
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - 回复
How big can the scratches be ?
Albert zweisteim - 回复
How do you get it shiny again?
lucas cheraki - 回复
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 234
过去 30 天: 999
总计 75,411
