跳转到主内容
Repairing the Loose Hands on a Fossil Women's Metallic Scarlette Es4314 Watch
你所需要的
  1. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch, Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 1 中的图像 1,2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch, Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 1 中的图像 2,2
    • Disconnect wrist band by using the right size Push Pin for your watch to push the Spring Shaft back through the watch band hole.
    • Simultaneously push the Spring Shaft down and gently pull the band and shaft away, releasing the band.
    • By disconnecting the wrist band you will be able to open and work on the back of the watch with ease.
  2. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 2 中的图像 1,2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 2 中的图像 2,2
    • Place watch face down in the watch holder.
    • Tighten the holder with the wing nut on the side of the watch holder until watch is snug.
    • Righty tighty, lefty loosey
  3. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 3 中的图像 1,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 3 中的图像 2,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 3 中的图像 3,3
    • Identify the correct size tooth that matches the indention on your watch's back case.
    • Screw the three identical teeth into the back case screw driver and use the wheel on the top of the screw driver to line the teeth up with the intentions on the back case.
    • Line up the teeth to the small indentions on the back of the watch, apply a slight amount of pressure, and unscrew the back case of the watch.
    • Some watches may need to be opened with a small Pry Tool, however for this particular watch you will need to utilize the watch screwdriver.
  4. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 4 中的图像 1,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 4 中的图像 2,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 4 中的图像 3,3
    • Once the back of the watch is removed, use tweezers to carefully remove the first two plates which are connected.
  5. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 5 中的图像 1,2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 5 中的图像 2,2
    • Once the gears are exposed, inspect gears for any disconnection. If no issues are discovered, investigate other connecting parts.
    • Locate the small metal connector arm that is touching the gears and turning the minute and second hands. If it is not connecting, remove it and adjust it as needed.
    • Note: This was a very small metal arm at the bottom of the picture
  6. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 6 中的图像 1,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 6 中的图像 2,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 6 中的图像 3,3
    • Remove any components you need to in order to allow you access to the connector piece.
    • Stay organized in this process as the pieces are very small and layered in a complex order. I also recommend getting a magnifying glass as some of the pieces are very small.
  7. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 7 中的图像 1,2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 7 中的图像 2,2
    • Use the small mallet and tweezers from your kit to straighten and adjust your connector piece so that it makes direct contacts with the gears.
  8. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 8 中的图像 1,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 8 中的图像 2,3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: 步骤 8 中的图像 3,3
    • After straightening the bent connector, reassemble your watch by starting at Step 6 and working backwards to Step 1.
结论
To reassemble your device, follow these instructions in reverse order starting at Step 6 and working backward to Step 1. It is imperative to replace all pieces back in the correct order. Take your time and don’t forget to breathe!
另外一个人完成了本指南。
Amanda Catarzi
于02/01/20注册
187 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 30
总计 1,912
