跳转到主内容
Seville Classics MSC10166 Buttons Replacement
你所需要的
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): 步骤 1 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Buttons Replacement: 步骤 2 中的图像 1,1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: 步骤 5 中的图像 1,2 Seville Classics MSC10166 Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: 步骤 6 中的图像 1,1
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: 步骤 8 中的图像 1,1
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: 步骤 9 中的图像 1,1
    • Wipe down the frame that holds the buttons.
结论
2等其他人完成本指南。
Queena Phung
于09/26/12注册
114 声望
创作了3篇指南
团队
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G46
5 名成员
创作了6篇指南
2条评论
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - 回复
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 3,915
