当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the screw from the pad arm.
If the screw is missing, get a backup screw, and proceed to step 2.
Insert the nose pad into the mount on the frame.
Make sure the nose pad lines up with the screw hole.
While holding the nose pad in place, use the magnet to attract the screw head.
Make sure the screw is vertical to the magnet and the screw head is above.
Using a horizontal motion, remove the magnet.
Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
Make sure the screw is tightened enough.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
