跳转到主内容
简介
This guide will walk you through our repair process step by step on how to reattach a loose nose pad on a pair of eyeglasses. You will need a nose pad, a 1.0mm flathead screwdriver, a magnet, and an extra screw if you have lost the one on your eyeglasses.
We feel this guide is necessary because according to our research, myopia is affecting nearly 40 percent of the US population. In addition, based on our own experiences, nose pads are normally the weakest part of the glasses. For those who need their glasses every day, knowing how to repair the nose pads by themselves is extremely useful.
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: 步骤 1 中的图像 1,2 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: 步骤 1 中的图像 2,2
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: 步骤 2 中的图像 1,2 Repairing nose pads on eyeglasses: 步骤 2 中的图像 2,2
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: 步骤 3 中的图像 1,1
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: 步骤 4 中的图像 1,2 Repairing nose pads on eyeglasses: 步骤 4 中的图像 2,2
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: 步骤 5 中的图像 1,2 Repairing nose pads on eyeglasses: 步骤 5 中的图像 2,2
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
结论
3等其他人完成本指南。
Vivi Chou
于2017年04月28日注册
151 声望
撰写一个指南
团队
UC Davis, Team S3-G4, Coad Spring 2017 UC Davis, Team S3-G4, Coad Spring 2017 的会员
UCD-COAD-S17S3G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 90
过去 30 天: 462
总计 37,870
