跳转到主内容
加入维修社区 - 创建账户
Repairing and Reinforcing a Closet Rack
你所需要的
    1. Repairing and Reinforcing a Closet Rack, Brackets Braces C-Clamps: 步骤 1 中的图像 1,1
      • Use the putty knife and spread the dry wall compound filling any holes and damage made to the wall.
      询问修复机器人
      添加评论
    2. Repairing and Reinforcing a Closet Rack: 步骤 2 中的图像 1,1
      • Allow the compound to dry off so as to reach maximum hardness.
      询问修复机器人
      添加评论
    3. Repairing and Reinforcing a Closet Rack: 步骤 3 中的图像 1,1
      • Use the 100 grit sandpaper and gently sand down the areas that were puttied, thus making them flush with the wall.
      • Use safety glasses and a dust mask protecting both your lungs and eyes from any particles coming off the wall.
      询问修复机器人
      添加评论
    4. Repairing and Reinforcing a Closet Rack: 步骤 4 中的图像 1,1
      • Measure and mark where the new holes will go for the brackets, c-clamps, and braces.
      • Allow 11"-12" of space between the side wall and the first bracket and each subsequent bracket.
      • Mark holes for the c-clamps half the distance between the brackets.
      • Use a level to guarantee the rack will be straight.
      询问修复机器人
      添加评论
    5. Repairing and Reinforcing a Closet Rack: 步骤 5 中的图像 1,1
      • Use a drill with a 1/4" drill bit and make holes at each mark.
      • Use safety glasses when operating the drill, and be cautious and careful when handling the drill. Careless handling of the drill can lead to injury. For more information on how to properly handle a drill refer to this guide's introduction.
      添加评论
    6. Repairing and Reinforcing a Closet Rack: 步骤 6 中的图像 1,1
      • Use a hammer and knock the plastic anchors into the wall where the holes were drilled.
      • Use #8 plastic anchors for best results.
      询问修复机器人
      添加评论
    7. Repairing and Reinforcing a Closet Rack: 步骤 7 中的图像 1,1
      • Use a brush and matching wall paint to coat the areas that were puttied and allow it to dry.
      询问修复机器人
      添加评论
    8. Repairing and Reinforcing a Closet Rack: 步骤 8 中的图像 1,1
      • Use a flathead screwdriver and screw the brackets into the plastic anchors.
      • Use 1-1/4" flathead screws for best results.
      询问修复机器人
      添加评论
    9. Repairing and Reinforcing a Closet Rack: 步骤 9 中的图像 1,1
      • Take the closet rack and place it onto the brackets.
      询问修复机器人
      添加评论
    10. Repairing and Reinforcing a Closet Rack: 步骤 10 中的图像 1,1
      • Use a Phillips screw driver to screw the c-clamps into the plastic anchors and reinforce the rack.
      • Use Phillips #8 1-1/4" screws for best results.
      询问修复机器人
      添加评论
    11. Repairing and Reinforcing a Closet Rack: 步骤 11 中的图像 1,1
      • Place the support braces on the rack.
      • Use a Phillips screw driver to screw them into the plastic anchors.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
1指南评论
Just a question what if you wanted to install a heavier more solid longer rod?
Chris M - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 148
总计 12,936
