跳转到主内容
Repairing a trackpad that clicks but won't register
你所需要的
  1. Repairing a trackpad that clicks but won't register, Remove the lower case screws: 步骤 1 中的图像 1,1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. Repairing a trackpad that clicks but won't register, Lift the lower case away: 步骤 2 中的图像 1,1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. Repairing a trackpad that clicks but won't register, Battery: 步骤 3 中的图像 1,1
    • Remove the following tri-point screws securing the battery to the upper case:
    • One 5.5 mm tri-point screw.
    • One 13.5 mm tri-point screw.
  4. Repairing a trackpad that clicks but won't register: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  5. Repairing a trackpad that clicks but won't register: 步骤 5 中的图像 1,1
    • Lift the battery out of the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Repairing a trackpad that clicks but won't register, Trackpad: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to carefully pry the trackpad connector up from its socket on the logic board.
  7. Repairing a trackpad that clicks but won't register: 步骤 7 中的图像 1,1
    • Open your MacBook Pro and set it on a table as shown.
  8. Repairing a trackpad that clicks but won't register: 步骤 8 中的图像 1,1
    • While holding the edge of the trackpad closest to the logic board with one hand, remove the four 1.2 mm Phillips screws highlighted in red.
  9. Repairing a trackpad that clicks but won't register: 步骤 9 中的图像 1,3 Repairing a trackpad that clicks but won't register: 步骤 9 中的图像 2,3 Repairing a trackpad that clicks but won't register: 步骤 9 中的图像 3,3
    • If necessary, carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
    • Carefully push the trackpad connector and cable down through the slot cut into the upper case.
    • It may be necessary to use a spudger to help get the trackpad connector past the edge of the logic board.
    • Once the cable has been completely pulled through its slot in the upper case, pull the trackpad away from the outer edge of the upper case and remove it from the machine.
  10. Repairing a trackpad that clicks but won't register: 步骤 10 中的图像 1,1
    • If you are installing a replacement trackpad that didn't come with the attached flex cable, you'll need to use the cable from your old trackpad.
    • To remove the flex cable from the old trackpad, first flip open the latch on the ZIF connector, opposite the cable. Then, apply a little heat from a hair dryer or iOpener to soften the adhesive securing the cable to the trackpad, and carefully peel off and remove the cable.
    • When installing your new trackpad, routing the cable through the upper case and past the logic board may be difficult. It is helpful to use the tip of a spudger to guide the connector past the logic board while pushing the cable through its slot in the upper case with your other hand.
  11. Repairing a trackpad that clicks but won't register: 步骤 11 中的图像 1,2 Repairing a trackpad that clicks but won't register: 步骤 11 中的图像 2,2
    • Next, reinstall the four 1.2 mm Phillips screws along the inner edge of the trackpad.
    • Tighten the screws all the way, then back them out about 1/4 turn.
    • Check the alignment of the trackpad on the keyboard side of the upper case. Once you have centered the trackpad in the upper case, tighten the four Phillips screws all the way.
  12. Repairing a trackpad that clicks but won't register, Lift the tape: 步骤 12 中的图像 1,1
    • Using a small X-Acto knife or pin, carefully lift the tape. Peel it back to lift the top of the contact switch.
    • NOTE: Do not completely remove the tape. Leave the other side attached as shown in the next step. This will allow you to easily align the top contact with the bottom after cleaning.
  13. Repairing a trackpad that clicks but won't register, Clean the contact: 步骤 13 中的图像 1,1
    • Once the contact is revealed, use a Q-tip with a small amount of Isopropyl Alcohol (91%) to wipe both the top and bottom of the contact.
  14. Repairing a trackpad that clicks but won't register, Replace the tape: 步骤 14 中的图像 1,1
    • Place the tape back down and rub it with your fingernail or a plastic spudger to assure contact.
结论
To reassemble your device, follow these instructions (From Step 11) in reverse order.
17等其他人完成本指南。
scottgriz
于02/04/10注册
966 声望
撰写一个指南
15条评论
In the other trackpad replacement guide, it doesn't have this tip, to take off the clicker and clean it. I did just that thanks to this guide and the clicker is now working reliably again.
Neil Snape - 回复
That's great. The one I repaired this way has been working great. The original replacement guide is just that. It's meant to remove the trackpad and replace it with a new one. I figured I had nothing to lose by digging a little deeper to fix the one I had and this guide is the result. Glad it was helpful.
Scott
scottgriz -
Great tip, I thought I was going to have to replace my track pad too but this fixed it up.
zapper222 - 回复
Wish I would have read this before buying a new track pad! Thanks for all your expert information on this site, much appreciated.
rileyjim - 回复
Awesome guide! it was very helpfull and acurate ! Thanks, my trackpad came back to life!
Andrés Lloret - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 32
总计 6,261
