跳转到主内容
Repairing a Wobbly Piano Bench
你所需要的
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: 步骤 1 中的图像 1,1
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: 步骤 2 中的图像 1,1
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: 步骤 3 中的图像 1,3 Repairing a Wobbly Piano Bench: 步骤 3 中的图像 2,3 Repairing a Wobbly Piano Bench: 步骤 3 中的图像 3,3
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: 步骤 4 中的图像 1,3 Repairing a Wobbly Piano Bench: 步骤 4 中的图像 2,3 Repairing a Wobbly Piano Bench: 步骤 4 中的图像 3,3
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: 步骤 5 中的图像 1,1
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: 步骤 6 中的图像 1,2 Repairing a Wobbly Piano Bench: 步骤 6 中的图像 2,2
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: 步骤 7 中的图像 1,2 Repairing a Wobbly Piano Bench: 步骤 7 中的图像 2,2
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
结论
You can redo this process every 6 months to make sure your bench is always stable.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 27
总计 1,165
