跳转到主内容
Repairing a Tear in a Tent
你所需要的
  1. Repairing a Tear in a Tent, Sew a Ladder Stitch: 步骤 1 中的图像 1,3 Repairing a Tear in a Tent, Sew a Ladder Stitch: 步骤 1 中的图像 2,3 Repairing a Tear in a Tent, Sew a Ladder Stitch: 步骤 1 中的图像 3,3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Repairing a Tear in a Tent: 步骤 2 中的图像 1,2 Repairing a Tear in a Tent: 步骤 2 中的图像 2,2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Repairing a Tear in a Tent: 步骤 3 中的图像 1,2 Repairing a Tear in a Tent: 步骤 3 中的图像 2,2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Repairing a Tear in a Tent: 步骤 4 中的图像 1,2 Repairing a Tear in a Tent: 步骤 4 中的图像 2,2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Repairing a Tear in a Tent: 步骤 5 中的图像 1,3 Repairing a Tear in a Tent: 步骤 5 中的图像 2,3 Repairing a Tear in a Tent: 步骤 5 中的图像 3,3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
    Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
    Kathleen Slamka - 回复
    We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
    https://www.amazon.com/Fixmytear-Magic-R...
    https://www.amazon.com/fixmytear-Magic-R...
    W731620 E - 回复
终点
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
89,011 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
一条评论
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
bobhunter50023 - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 72
过去 30 天: 261
总计 7,632
