跳转到主内容
Repairing a Panasonic SA-HT810V with the H02/H07 error
你所需要的
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 1 中的图像 1,3 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 1 中的图像 2,3 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 1 中的图像 3,3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 2 中的图像 1,2 Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 2 中的图像 2,2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 3 中的图像 1,1
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 4 中的图像 1,2 Repairing a Panasonic SA-HT810V with the H02/H07 error: 步骤 4 中的图像 2,2
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
结论
另外一个人完成了本指南。
Nathan Cheadle
于04/15/10注册
161 声望
创作了7篇指南
团队
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G5
4 名成员
创作了7篇指南
3条评论
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - 回复
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - 回复
Can’t get screws undone on ours… Help!
Matthew - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 27,525
