跳转到主内容
Repairing a Cordless Drill Battery
  1. Repairing a Cordless Drill Battery, Repairing a Cordless Drill Battery: 步骤 1 中的图像 1,3 Repairing a Cordless Drill Battery, Repairing a Cordless Drill Battery: 步骤 1 中的图像 2,3 Repairing a Cordless Drill Battery, Repairing a Cordless Drill Battery: 步骤 1 中的图像 3,3
    • This battery operation concerns 12Volt, 14.4V and 16,8V cordless drills. First open the pack. Take out the battery cells. and disconnect the connector on the top.
  2. Repairing a Cordless Drill Battery: 步骤 2 中的图像 1,3 Repairing a Cordless Drill Battery: 步骤 2 中的图像 2,3 Repairing a Cordless Drill Battery: 步骤 2 中的图像 3,3
    • Next step is to take a 15cm long speaker cable. To one side you press 2 slide connectors. The other side you solder the top connector of the old battery pack. take care with the polarity. You can see the plus and the minus on top.
  3. Repairing a Cordless Drill Battery: 步骤 3 中的图像 1,3 Repairing a Cordless Drill Battery: 步骤 3 中的图像 2,3 Repairing a Cordless Drill Battery: 步骤 3 中的图像 3,3
    • When the cable is done we can push the top connector back. To hold this in place we have to make a spacer from wood.
  4. Repairing a Cordless Drill Battery: 步骤 4 中的图像 1,3 Repairing a Cordless Drill Battery: 步骤 4 中的图像 2,3 Repairing a Cordless Drill Battery: 步骤 4 中的图像 3,3
    • Now we have to find a way to connect the battery to the old box. The best condition is when the battery fits exact in the old battery box and that this can be closed. When not there is a possibility to use tie wraps to hold all in place. An other way is to saw the box open. On the last photo's you see how a Black and Decker is hacked.
    • So, this is it. There is also a video on YouTube about this hack. Here you find the instruction video
  5. Repairing a Cordless Drill Battery: 步骤 5 中的图像 1,2 Repairing a Cordless Drill Battery: 步骤 5 中的图像 2,2
    • Last but not least the question; how to charge the lead gel battery? For a 12Volt drill you can use the usual charger. For drills with a higher voltage you have to use an adaptor with a 12V till 14 V unstabilized DC output. Its easy to connect the adaptor cable to the charger because there is no electronics build in.
    • Addition: To avoid wasting the old adaptor, you can use a charger IC. It is the PB137. You need only 2 capacitors extra. See the diagram. The input voltage can be between 16 and 40 Volt DC. This circuit fit's easy within the charger unit.
结论
3等其他人完成本指南。
Berto A
于06/12/13注册
300 声望
撰写一个指南
2条评论
Thank you for the good article. I tried to make my own comparison table of the cordless drills and got the following results: https://www.firstcordlessdrillreviews.co... , it is a usefull guide for people who decided to buy a drill and who don’t know nothing about them.
Albertosi - 回复
It is so helpfull of the article.  We can buy some battery cells, and replace its by ourself when the drill battery is died.
Drillbatterycomau - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 147
总计 36,344
