跳转到主内容
Repairing a Broken or Loose Paper Towel Hanger
你所需要的
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: 步骤 1 中的图像 1,1
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: 步骤 2 中的图像 1,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 2 中的图像 2,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 2 中的图像 3,3
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: 步骤 3 中的图像 1,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 3 中的图像 2,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 3 中的图像 3,3
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: 步骤 4 中的图像 1,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 4 中的图像 2,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 4 中的图像 3,3
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: 步骤 5 中的图像 1,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 5 中的图像 2,3 Repairing a Broken or Loose Paper Towel Hanger: 步骤 5 中的图像 3,3
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
结论
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
于09/08/23注册
121 声望
撰写一个指南
团队
York University, Team 1-21, O'Regan Fall 2023 York University, Team 1-21, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G21
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 145
