跳转到主内容
Repairing VTech Touch and Swipe Baby Phone Battery Pack
你所需要的
  1. Repairing VTech Touch and Swipe Baby Phone Battery Pack, Battery: 步骤 1 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Battery Pack, Battery: 步骤 1 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 2 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 2 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 2 中的图像 3,3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 3 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 3 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 3 中的图像 3,3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Repairing VTech Touch and Swipe Baby Phone Battery Pack, Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 4 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Battery Pack, Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 4 中的图像 2,2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 5 中的图像 1,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 5 中的图像 2,3 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 5 中的图像 3,3
    • Remove the 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away the battery pack being careful not to tug on the wiring.
  6. Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 6 中的图像 1,2 Repairing VTech Touch and Swipe Baby Phone Battery Pack: 步骤 6 中的图像 2,2
    • If the batty casing solder has been disconnected you will see that the pair of red and black wires near the battery pack are no longer connected.
    • You will need to solder back on these wires to the two silver soldering plates on the battery case. The black wire should be soldered on to the plate closer next to the square plastic piece attached.
    • Make sure to correctly solder each wire as shown, because if you solder the red wire where the black wire should be your device will not function.
结论
另外一个人完成了本指南。
Zack Drawdy
于09/04/15注册
231 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 7
总计 335
