跳转到主内容
Repairing Toyota Sienna air filter vacuum connector
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Repairing Toyota Sienna air filter vacuum connector, Repairing Toyota Sienna air filter vacuum connector: 步骤 1 中的图像 1,1
    • 2008 Toyota Sienna airfilter with broken plastic vacuum connector thanks to a reckless oil change facility.
  2. Repairing Toyota Sienna air filter vacuum connector: 步骤 2 中的图像 1,1
    • Remove cover for the vehicle and carefully saw off the rest of the broken connector so it is flush with the cover and will be easier to drill out.
  3. Repairing Toyota Sienna air filter vacuum connector: 步骤 3 中的图像 1,1
    • Drill out the old remaining connector with a 9/32 inch drill bit. ** you must use a 9/32 only so that the new metal connector with fit snug.**
  4. Repairing Toyota Sienna air filter vacuum connector: 步骤 4 中的图像 1,2 Repairing Toyota Sienna air filter vacuum connector: 步骤 4 中的图像 2,2
    • Insert new metal connector with a little loctite glue using a small box wrench.
  5. Repairing Toyota Sienna air filter vacuum connector: 步骤 5 中的图像 1,1
    • Replace airfilter (new one if needed) and re-attach vacuum hoses to housing in car. Pat self on the back for saving $400.
结论
To reassemble your device, follow these instructions.
6等其他人完成本指南。
broadws
于09/23/12注册
228 声望
撰写一个指南
3条评论
Good luck finding the fitting! I tried three auto parts stores (including ones whose websites falsely said they had them in stock), and finally settled for an adapter at Lowes. The threaded side was about half an inch but I made it work. I'm still disgusted that the dang vacuum fitting was so flimsy to begin with.
Jesus - 回复
Part was out of stock for a while. Now available for $9.25
broadws -
Thank you for helping me save some serious $$$. I was going to update this with photos, but since I ended up using a different fitting from Lowe's (addressing Jesus's comment), I decided that the details were sufficiently different to merit being a different guide. See it at Repairing Toyota Sienna Air Filter Vacuum Connector.
Steven Paradise - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,868
