简介
Flat/leaky tires are a part of life. Tires are made of rubber and therefore can be punctured. While there is little anyone can do to prevent this, a simple fix is available. When a nail or any other sharp object punctures a hole in a car tire it causes the tire to leak air consistently, which can be very dangerous if not fixed. Using a few simple tools, a punctured tire can be fixed using a tire plug. Remember to be sure to perform the repair on level ground. The car engine should be off and the parking brake engaged.
你所需要的
Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
4等其他人完成本指南。
一条评论
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
