跳转到主内容
Repairing Tire Hole/Puncture
你所需要的
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: 步骤 1 中的图像 1,1
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: 步骤 2 中的图像 1,1
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: 步骤 3 中的图像 1,2 Repairing Tire Hole/Puncture: 步骤 3 中的图像 2,2
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: 步骤 4 中的图像 1,1
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: 步骤 5 中的图像 1,1
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: 步骤 6 中的图像 1,3 Repairing Tire Hole/Puncture: 步骤 6 中的图像 2,3 Repairing Tire Hole/Puncture: 步骤 6 中的图像 3,3
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: 步骤 7 中的图像 1,1
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: 步骤 8 中的图像 1,1
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: 步骤 9 中的图像 1,1
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: 步骤 10 中的图像 1,1
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: 步骤 11 中的图像 1,2 Repairing Tire Hole/Puncture: 步骤 11 中的图像 2,2
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
结论
4等其他人完成本指南。
团队
Missouri Western, Team 1-5, Adkins Fall 2015 Missouri Western, Team 1-5, Adkins Fall 2015 的会员
MWSU-ADKINS-F15S1G5
1 名成员
创作了1篇指南
一条评论
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 95
总计 5,546
