跳转到主内容
加入维修社区 - 创建账户
Repairing Tent Buckle
你所需要的
  1. Repairing Tent Buckle, Sew a Straight Stitch: 步骤 1 中的图像 1,2 Repairing Tent Buckle, Sew a Straight Stitch: 步骤 1 中的图像 2,2
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
  2. Repairing Tent Buckle: 步骤 2 中的图像 1,2 Repairing Tent Buckle: 步骤 2 中的图像 2,2
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
  3. Repairing Tent Buckle: 步骤 3 中的图像 1,2 Repairing Tent Buckle: 步骤 3 中的图像 2,2
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
  4. Repairing Tent Buckle: 步骤 4 中的图像 1,2 Repairing Tent Buckle: 步骤 4 中的图像 2,2
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
  5. Repairing Tent Buckle: 步骤 5 中的图像 1,3 Repairing Tent Buckle: 步骤 5 中的图像 2,3 Repairing Tent Buckle: 步骤 5 中的图像 3,3
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
  6. Repairing Tent Buckle: 步骤 6 中的图像 1,1
    • Cut any remaining thread and admire your work.
终点
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
90,621 声望
创作了142篇指南
1指南评论
I've found that small bungee cords (or the poor-boy version, an old bicycle inner tube cut with a scissors into very many tough rubber bands just as thick or thin as you wish) is a great add-on to tent and tarp guy lines. When those big gusts of wind arrive, the elasticity of the added-on stretchy thing allows the wind to buffet the tent or tarp about, but prevents tent stakes from being dislodged, or tarps from becoming shredded. No stitches are needed when the elastic, instead of the fabric, takes the strain.
Brendan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 5,467
