跳转到主内容
Repairing TRITTON Kunai Left Speaker
你所需要的
  1. Repairing TRITTON Kunai Left Speaker, Repairing TRITTON Kunai Left Speaker: 步骤 1 中的图像 1,2 Repairing TRITTON Kunai Left Speaker, Repairing TRITTON Kunai Left Speaker: 步骤 1 中的图像 2,2
    • Grab the ear cushion between your thumb and finger.
    • Carefully pull the ear cushion away from the speaker frame until they separate.
  2. Repairing TRITTON Kunai Left Speaker: 步骤 2 中的图像 1,2 Repairing TRITTON Kunai Left Speaker: 步骤 2 中的图像 2,2
    • Use your Phillips #00 screwdriver to remove the two 9mm screws.
    • Use your Phillips #00 screwdriver to remove the two 7mm screws.
    • Remove the now detached black cover from the hinge frame.
  3. Repairing TRITTON Kunai Left Speaker: 步骤 3 中的图像 1,2 Repairing TRITTON Kunai Left Speaker: 步骤 3 中的图像 2,2
    • Use your Phillips #00 screwdriver to remove the two 7mm screws holding the bracket, headband, and hinge assembly together.
    • Seperate the bracket, headband, and speaker housing's hinge.
  4. Repairing TRITTON Kunai Left Speaker: 步骤 4 中的图像 1,2 Repairing TRITTON Kunai Left Speaker: 步骤 4 中的图像 2,2
    • Use your Phillips #00 screwdriver to remove the six 7mm screws holding the black speaker housing to the wiring housing.
    • Carefully separate the black speaker housing from the wiring housing.
    • Be gentle, the wires and solder points inside are fragile.
  5. Repairing TRITTON Kunai Left Speaker: 步骤 5 中的图像 1,1
    • This is the circuit board for the USB connection to the speakers.
    • Inspect the five solder points for a broken wire connection. They are labeled SP-, M-, M+, R-, and R.
    • If any connections are broken, re-solder the wires. Use this image as a reference for correct wiring.
    • Carefully test the headset. Avoid touching the internals while the device is plugged in.
    • If your speaker is now working, skip to the conclusion.
    • Reinforcing the wires with electrical tape before reassembly is recommended.
  6. Repairing TRITTON Kunai Left Speaker: 步骤 6 中的图像 1,1
    • This the back of the left ear speaker inside the black speaker housing.
    • The red wire connects to the leftmost terminal and the white wire connects to the rightmost terminal.
    • Inspect the red and white wires and two solder points for a broken connection to the speaker.
    • If your speaker is still not working, you may need to replace the speaker or USB circuit board. Please refer to the manufactures product specs from their website for further details.
结论
To reassemble your device, follow steps 1 through 4 in reverse order.
另外一个人完成了本指南。
Timothy Meyer
于03/26/15注册
155 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,512
