跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
Thorough knowledge of disassembling the camera is necessary for replacing the motherboard.
  1. Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Slide the blue locking tab to release the battery.
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera. Remove the four 2.5mm Phillips #0 screws.
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Turn the camera so the left side-panel reading "5x Optical Zoom" faces you. Remove the two 2.5mm Phillips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Turn the camera so the right side faces you. Remove the two 2.5mm Phillips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
    • Turn the camera so the right side faces you.
  6. Rotate camera so that the back is facing you.
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Turn the camera so that the left side is facing you. Pull the left side-panel off of the camera.
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Turn camera so that the front of the camera is facing you. Pull the front casing directly away from the camera.
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Turn the camera so that the right side is facing you. Pull the right side-panel away from the rest of the camera.
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. This is what your camera should look like now that you have removed the casing from all sides. This is what your camera should look like now that you have removed the casing from all sides.
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Gently pull the LCD and its casing away from the motherboard as shown.
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard. Do not use excessive force to remove the wire because this may cause it to tear.
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard. Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Pull the LCD and its casing away from the rest of the camera.
    • Pull the LCD and its casing away from the rest of the camera.
  15. Turn the camera so the back is facing you. Remove the 2.5mm Philips #0 screw at the top of the camera.
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
  16. Tilt top casing up and towards you. Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top. Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  17. Flash capacitors are dangerous! Be extremely careful when removing the capacitor from the camera. You can get shocked BADLY! Remove the flash capacitor from the lens assembly. Carefully place the flash capacitor away from where you are working.
    • Flash capacitors are dangerous! Be extremely careful when removing the capacitor from the camera. You can get shocked BADLY!
    • Remove the flash capacitor from the lens assembly.
    • Carefully place the flash capacitor away from where you are working.
  18. Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard. Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard. Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard.
    • Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard.
  19. Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard. Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard. Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard.
    • Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard.
  20. Pull the Lens Assembly away from the motherboard. You have now removed the Lens Assembly from the camera. You have now removed the Lens Assembly from the camera.
    • Pull the Lens Assembly away from the motherboard.
    • You have now removed the Lens Assembly from the camera.
  21. Remove the red clip that holds the motherboard to its casing. Remove the red clip that holds the motherboard to its casing. Remove the red clip that holds the motherboard to its casing.
    • Remove the red clip that holds the motherboard to its casing.
  22. Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing. Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing. Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing.
    • Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing.
  23. Lift the motherboard from the casing. Carefully remove the large ribbon-wire by pulling the wire where it connects with the motherboard. In order to completely remove the motherboard, you must desolder the small ribbon wire from the casing.
    • Lift the motherboard from the casing.
    • Carefully remove the large ribbon-wire by pulling the wire where it connects with the motherboard.
    • In order to completely remove the motherboard, you must desolder the small ribbon wire from the casing.
  24. Flip the motherboard up to turn it over. When de-soldering, be careful not to burn yourself or the motherboard. You can damage or destroy the motherboard or the ribbon wire by applying too much heat. Carefully de-solder the three connectors from the ribbon wire to the motherboard.
    • Flip the motherboard up to turn it over.
    • When de-soldering, be careful not to burn yourself or the motherboard. You can damage or destroy the motherboard or the ribbon wire by applying too much heat.
    • Carefully de-solder the three connectors from the ribbon wire to the motherboard.
    • You have now removed the motherboard.
结论
2等其他人完成本指南。
Evan Mayer
于2010年10月05日注册
318 信誉积分
创作了5篇指南
团队
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G54
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 3,753
