跳转到主内容
Revlon 473 Hair Dryer Switch Replacement
你所需要的
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: 步骤 1 中的图像 1,1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: 步骤 2 中的图像 1,1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: 步骤 3 中的图像 1,3 Revlon 473 Hair Dryer Switch Replacement: 步骤 3 中的图像 2,3 Revlon 473 Hair Dryer Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: 步骤 4 中的图像 1,1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: 步骤 5 中的图像 1,1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: 步骤 6 中的图像 1,1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
结论
另外一个人完成了本指南。
Jessica Leyva
于09/18/12注册
143 声望
创作了5篇指南
团队
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 1,781
